Help deleting line and font
Need help. I want to remove a line.the line that is cutting directly through fire department. Also the Seattle logo was imported so is there a way to delete the current font to add my own? When I did a test cut I did not like the font. It was hard to read. Would like to use a easier font. Thanks again.
Share your file as public so can help you. Is the skyline a separate file from the fire logo?
Thanks Steve. I thought I did. Sorry I’m new to this. Should I report it ? What did I miss?
Yes they are both separate
You can add a rectangle, the width of the line you dont want cut and set it to cut at 0, and send it backward so its positioned behind the fire department covering that line.
