I think this would be called inlay.
I am working with a wood cut and acrylic. I want to pocket cut the wood and make a insert/inlay with acrylic.
I want the acrylic to be cut as image shows as raised letters all on one plate.
My question is if I cut the pocket in the wood then cut the raised letters at same size will this fit into the pocket? The Inlay program only leaves the outline of the cut and not the full text. Ill add image in a moment to show that.
No. You have sharp corners in your design. A round endmill can cut sharp external corners, but internal corners will always have a radius. The inlay app is supposed to handle this for you.
Can you share your original design or your project?
