IMG_2957.HEIC (2.9 MB) IMG_2960.HEIC (1.9 MB) IMG_2961.HEIC (2.0 MB)
Hi
I can’t finish any project
https://www.dropbox.com/s/a9cxzd46hiwtb0a/IMG_2959.MOV?dl=0
Hi
Untighten the black plastic screw block your Z-screw run on, does anything change?
Hi HaldorLonningdal
Yes it solved the Z problem .
The Y-axis is not parallel how I fix it?
Excellent, this block should only be tightened enough so its firm. Tighten too much and the block can “skew” a little causing the screw to bind more easily.
Regarding your non-squared Y-axis I´d direct you to this search, these should help :
https://discuss.inventables.com/search?q=axis%20not%20parallell
Thank you so much
