Help! No response from Z axis
Just going through the set up process with my x carve and my z axis is not responding. I don’t hear any motor sounds and there is no movement at all. Any ideas what I can do to fix this? Thanks for your help!
Check that all wires are correctly connected on the X-Controller (with screws adequately tightened), and the plug is correctly oriented and fully seated in the stepper motor.
