Help troubleshooting issue
You are probably right. I just had the 2 icons for raster and offset on my mind. Looking at them now and see the offset starts in the center and my my whole theory is gone…:no_mouth: being quiet now
Are the ridges (steps) oriented in the same direction (Y+ or Y- side of track)
What are your cutting feed rates and acceleration values (GRBL value $120/$121)
Cut a square pocket in mdf, and post a picture
So I figured out what was going on. The eccentrics on the z were not tight enough. The dust shoe and hose was causing drag at both ends. Once I fixed those issues I had the classic non parallel problem. A piece of paper shimming at the top of the z rail fixed that.
They were not. See the drawing above on the left.
Tomorrow I will reskim the wasteboard.
I am having this same issue on the ends of flat cuts. Was this the fix?
