Hi
If anyone can help me get this file to run, I would greatly appreciate it!
For starters, I would use a V-Bit to carve this into the stock material.
I made a new file and pasted everything on your first workpiece into it and it still seemed to not make it very far with toolpath generated. I then noticed a few “I” shapes near the (0, 0) location and removed them since they seemed to not belong there.
I am going to let it run overnight and see where it is at in the morning since it still has not completed simulating the toolpaths.
I’ll let you know if I find something or if it even completes.
You can always contact Inventables Support and point them to the file.
{:0)
Brandon R. Parker
WOW!!! Thank You!!!
So, the only other change I made was to the depth; I made everything 0.028" deep.
I am not certain how long it took, but it did complete the toolpath generation at some point during the day today.
I can not say why it took so long, but it finished. I would send this file to Inventables’ Customer Support to see if they can determine why the toolpath generation is taking such a long time.
{:0)
Brandon R. Parker
Thank You So Very Much!!!
