Hello everyone. I’m trying to carve a small detailed piece, approximately 2" (circular) and need help in using the right bit. The inside of the circle has some fine detail and the 60 degree V bit is not working. Thanks, and hopefully everyone is doing good.
Depending on the design, you might be able to use a 30-Degree V-Bit or even a 10-Degree engraving bit.
What does the design look like?
{:0)
Brandon Parker
