Hex Key Holder - Metric (Compare 3D Printing vs CNC)
A simple hex key holder.
Holds 4 keys:
  • 3.5 mm
  • 3 mm
  • 2.5 mm
  • 2 mm
Made with some HDPE; cuts and mills so good!
I wanted an excuse to try modeling something in Fusion 360.
https://www.instagram.com/p/BgKTHbjF8tg/
Fusion 360 Model: Fusion
Eventually I will compare CNC vs 3D printing the same model (See this post for the 3D printed version)
Just use Easel… no need to drive a Cadillac when the vw-bug will do…
Unless you just want to drive a Cadillac. Nothing wrong with learning for the sake of learning.
@JeremyJohnstone You could probably use a simpler pocket operation to save time over the adaptive when milling something as forgiving as HDPE. Keep it up!
While true, another reason I wanted to use Fusion 360, is so I could CNC as well as 3D Print the same object from the same CAD model.
Here is the 3D printed version for those curious:
https://www.instagram.com/p/BgMBGVzF62a/
This looks great, nice work! Great stuff getting into fusion too, while there are easier options for basic jobs there is a lot to be gained from getting experience using it
I’d like to try something similar to tidy up my toolbox a bit, HDPE looks like a good option too
Ages ago did a similar project:
but modeled the tools in OpenSCAD:
