Home position settings
Hi, guys
I have two questions for the home position.
The bolow lists are my current setting.
$0=10
$1=25
$2=0
$3=2
$4=0
$5=0
$6=0
$10=115
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=70.000
$25=100.000
$26=250
$27=2.000
$30=255
$31=0
$32=1
$100=792.000
$101=793.000
$102=800.000
$110=1000.000
$111=1000.000
$112=600.000
$120=30.000
$121=30.000
$122=30.000
$130=300.000
$131=180.000
$132=45.000
The first question, when I press home button on the other software which are Lightburn or Grblcontrol. It goes to left and bottom for X and Y and the Z axis goes to the top as $23=3. Then I clicked get current positions and it showed X: -298.00 Y= -178.00 Z: -2.00.
Which setting I should change to get the current positions are 0,0,0 after the CNC goes to the its home position??
And for EASEL PRO, where is the Home button???
When I set my device with the EASEL PRO, I set the home position and It went the position, but I could not use any advantages of the homing switches with EASEL.
Please help me…
1 - During homing the machine reference is synced to your design enviroment. It doesnt matter what the machine coordinates show, positive or negative value.
2 - Easel / Easel Pro user interface do not have a homing button. You need to issue a $H comand in the Machine Inspector Console window.
Typical work flow:
  • Power machine ON
  • Do a homing cycle ($H)
  • Fasten your work piece and jog your bit over to your intended work zero position
  • In Easel, to set work zero, click Confirm Home Position during the setup process
    Home position do NOT equal homing position (switches)
