Is it possible to increase the feed rate while the machine is running?
I very often set the feed rate too slow, trying to be on the safe side, and then find myself in a position where it is taking 2 hours to carve something that could have taken 45min. But its hard to get the feed rate tuned in when every time I want to change it I have to start and stop the entire process.
Our new PicSender gcode streamer release supports changing the feedrate on the fly, providing there is only one feedrate setting at the beginning of your gcode file.
You can make a modified version of the testing procedure at Precise Bits (Calibrating Feeds and Speeds When Using Carbide Microtools), and test the bit yourself in the material. As long as you keep track of what worked best, you should only have to perform the test once per bit:material combination.
I modified the procedure so that after I cut a 4" line, I cut a 1"x1" square of material out and check the edges to see if I’m happy with how clean they are.
