I am having trouble changing the RPM in easel for my cnc 3018
In Easel, got to “Machine” and click on “Advanced” in the lower right corner. The menu you see below should appear. You want “Spindle Control” to be set to “Automatic” and then you select the default RPM speed. This speed will be used when your machine goes to cut something using Easel.
I don’t know of any way to change it mid carve. You will need to adjust this every time you want a different speed; for example if you want to cut wood versus acrylic.
