I have a cutout plan for a rocking horse project. I want to scale it down by 25%. I have printed out each page of the cutout. How can I get this on to the Easel software. Do I use Image Trace? Is there a way that I can convert the downloaded plans into an SVG file?
The image trace is easy but it isnt the most accurate i suggest running it through inkscapes image trace for a better result of the trace… PNG Picture to SVG for CNC Tutorial - Image Trace - YouTube
And you might also run into the issue that the generated file will be a thick shape with 2 lines as the perimeter rather than a single line like youd probably need.
Heres a quick video showing how to overcome that issue with image tracing a line drawing…
