How do I make a 2.5D puzzle?
I was working on trying to make a 2.5D puzzle that fits snugly together, but Easel is unable to import the svg. This is what it looks like, how can I successfully import it into easel while maintaining the depth? http://i.imgur.com/NP9nsx4.png
I don’t know the answer to your question, but that puzzle would look awesome, so I really hope you can figure out how to get it to carve!
not entirely sure since i have only messed with easel a few times. However, if I were to use it, I would break that file down into multiple files. One file per cut level. Import the first cut level and set it’s depth, then repeat for each depth. This way it will be much easier to select the curves. If they don’t have it already, it would be great if there were a layers panel to be able to turn on/off.
Hope this helps!
