I have the
X-Controller
Quiet Cut Spindle 300w (part # 30416-01)
48VDC Power Supply (part # 30353-03)
DC Spindle Speed Controller (part # 30417-01)
Isolated Relay Circuit (part # 30405-01)
Was origonly to be used with the gshild as seen in this video from inventables
but I now have a X-Controller.
Can i just plug my Quiet Cut Spindle into the X-Controller
red wire to spindle-pwn and black to ground
or do i still need to use 48 vdc power supply if so how do i wire up
will i still have to use the relay and speed controller
No. The Arduino/gShield and the X-controller source the PWM signal which can control a speed controller.
For the Arduino/gShield a 24 volt speed controller is built in to the power supply board that Inventables provides with the kit that you mount to the front of the 24 volt power supply.
You will still need to provide external components to have the speed control function with the X-controller.
