I’ve found a post about setting the maximum travel speed in the machine inspector, and I think I’ve done that, but the spindle still seems to be traveling between cuts at the same speed as it is cutting.
What did you do?
What are your settings for $110, $111, & $112?
What do you want them to be?
To change $110, just send $110 = 2000
(if you wanted the max feed to be 2000mm/min)
Max rapids ($110-112) determine the max allowed speed for each axis
All G0-commands (non-cutting motion) usually use max rapids, unless CAM-software (*) is told to use a different speed.
(* - CAM = whatever program that generate the tool paths, Easel does this automatically)
