I have notice some of the projects are in metric and some in imperial.
When I try to start a new project and starting entering the material dimensions in mm it converts it back to imperial inches. The only thing that I can seem to set in metric is the bit size.
Thanks.
Scott
In the bottom right corner of the art board you can change the project to mm
Well Duh! I was too busy looking through the menu options at the top that I missed it.
Thanks!
Scott
Can you change bit size to metric?
I usually do. Measure the bit’s cutting diameter and enter it in custom bit size with mm.
Hi, I am having an issue with Easel/XCarve. In my project it is set up in inches. My box is marked in inches, all measurements show in inches. but when it carves it prints in millimeters… Am I missing something somewhere? Any suggestions please.
