Why does bit selection determine whether something shows up to carve. For instance, I lay out a diagram, but it only shows up at right with lines to carve if I select the 1/32 bit
I’m guessing your cut type is either inside the lines or pocket? In which case it will only be able to get into your desig with a smaller bit.
If your trying to cut the design out, you’d need to set the cut type to “outside the line”
If yoh want a quick instructional video using your actual design you’d need to share the project.
On easel Go to projects>share and change it from private to unlisted and copy that link, then paste it over here… don’t worry it’s just a copy and we can’t actually change your original with the link
