How to change the size of the easel
Is there a manual that shows how to enlarge the easel size, as I have a 16.5" X 10" platter to carve?
Hi Ivan,
There are 2 settings for size in Easel. The first is your machine’s work area, which you can configure in the “Machine” menu, under “Edit your machine”:
Screenshot 2023-09-29 at 4.58.59 PM
The second is by changing the size of the material in the dropdown in the upper right:
Hope this helps.
Cheers,
Jeff
Through trial and error, I did that. However, the total working area is not covered.
Thanks JT
Advice needed and greatly appreciated. Mrpro.
