How do i get mm in easel box apps
On the design screen lower left side you will find a slide toggle. Slide it to the right for mm
Philip thx but, I didn´t see that before I imported the box in box app
But in the other box generator Box Maker Classic
there is no way to set it to mm.
Correct, only certain Apps follow the inch/mm selection toggle.
Box Maker Classic fails to clarify that all values entered will be inches, however that is actually the case with this app.
When using Box Maker Classic you will need to convert mm to inches by taking your desired mm value and dividing by 25.4 to find the inch equivalent and then enter that value.
