Hello! Looking for a way to increase the polycount on a curve. It seems that Easel is decreasing the .dxy polycount upon import so my gentle and smooth curves are coming out too blocky…
Any help would be greatly appreciated!
Thank you,
Brad
Thank you,
Brad
Brad,
I’m not sure this is related but I thought I’d post it just in case. I’m not too clear on all of it but I remember reading this some time ago.
-Jonathan
Easel doesn’t support arc toolpaths so even if the design has arcs itll be converted to a segmented polygon when the toolpath is generated. Sure more polylines will help with this but itll also slow down the carve due to acceleration and deceleration through each node. The use of proper arcs would be preferred, if easel supported them…
