I’m new to Inventables and my X-carve, so maybe I’m missing something, but is there any way to make a 90 degree arc/curve cut easily? I could make a whole bunch of points on the line tool but that’s not really a good curve…
Thanks in advance…
Thanks in advance…
Not sure i am understanding you right but are you wanting like a half circle?
make a circle and stretch it to get the desired arch/length. Then cover up what you don’t need with a white box
Thanks for the replies, I watched the tutorial and what I was looking for was actually pretty simple - make a line, then select one of the dots and change it to arc. Unfortunately the circle/square thing won’t work as I need multiple 90 degree arc lines right next to each other and covering up with squares would interfere with the other lines.
