I got my x-carve and set it up ran my test cut all went well the problem is it will only carve a 10”x8” what I’m not doing…I’m new at this need help
Are you saying the grid size is only 10x8 or you can not change the project size?
I want to make my project fit the size of my board if I a board 15”x12” I can only cover 8”x6” what do I need to do to cover my work peace thanks for your help
If i understand you right after you have your project downloaded highlight the whole thing then touch on the corner and drag it out to the size you need. If you need to download the file here and we can take a look at it and help you.
