How to set motor current using a mac
Hello Everyone,
I looked through the forums and instructions multiple times and I must be missing the answer.Thank you for your patience. I am a Mac user and have finished building our new X-carve 1000mm. The build went smoothly until I clicked on “set motor current”. Now I feel like I am in over my head.
I was able to follow along until I got to "Then issue a very long Gcode command for that axis, something like g0x1000.**
How/where do I issue Gcode on a Mac???
Thank you very much for your help
Greg
Greg, are you using Easel, Chilipepper, or UGS?
You will need one of these on your Mac before you can issue a Gcode command.
If you are using Easel, you will need to request the ability to send Gcode, since it is in beta testing. Here is the link.
Thank you Michael,
I just sent in my request. I really appreciate the help!!
Greg
You can send single-line commands to the X-Carve from Easel without the gcode import beta access.
Just go to Machine --> Advanced --> Machine Inspector and you’ll see a dialog box that says “Console” In that box you can enter single line commands like the one you need.
Hi Phil,
I am/was trying to figure out how to send Gcode via my Mac.
Greg
Thanks Mike,
I will try that.
Greg
I appreciate the help.
