How to you change the “Raise the bit” height in easel ? I could do with an extra 3mm on the raise the bit height so that a dust boot will clear the collet chuck, can do it manually in easel, but I thought it would be easier to change in easel somewhere ? Thanks in advance.
Just go to machine and advanced and it should show your saftey height and you can change it there.
Thank you ! just changed it and it works, Cheers.
You will need to change it with each project because it will go back to the default setting when you open a new one.
Mine doesn’t
Mine will stay the same with the program you set it up for. But if i make a new project i need to reset it if i want it higher.
