Hello,
I would like to cut this item I created in fusion 360 with my xCarve using easel.
The problem is the angled slope. I dont mind hand/carving some bits so make it perfect.
Hello,
Easel doesn’t do 3D carving. But you can use Fusion 360 to generate the tool path(s), then send it to your XCarve using a g-code sender, such as UGS.
You can export gcode from F360 and run straight through Easel, just make sure you use the appropriate post processor and that your gcode dont utilize the G28 command.
