I can now use my X-Carve to drill precise holes for the masts of my hydrofoil projects.
First, I cut a hole in the top of my waste board, and added some clamps on bothe sides.
And I added a board below, with a similar hole and clamps.
Now I can drill precise holes in the top of the mast.
Looking good.
Cool solution! Exploring the “Z-minus” plane. I like it.
Nice. When I saw the title I thought something else. hehehe.
I like your clamping method more than I like the holes
I may use those clamps for projects where I don’t want anything on top of the piece I am working on. I have to screw them into the waste board, but those are small holes.
Great seeing folk thinking laterally.
I’m always kinda amused/surprised when I read about people stressing about their wasteboards. I read in another post somewhere how some of us could probably be identified by the various scarring and burning on our wasteboards, and I think they’re probably correct.
While there’s a dozen ways to manage things, my el-cheapo solution was to break the wasteboard into bits right from the beginning. This way, each one is sacrificial and replacing the most-used section, doesn’t mean replacing the whole thing. I can also remove one section to access the hole cut through the table below allowing me to work on the ends of longer material.
I have to resurface things sometimes, but with thicker mdf, that not really an issue. My ways isn’t any better, it’s just another way…
The new joint is holding. I really wouldn’t be this far advanced in building my own hydrofoil without my X-Carve.
It is listed as a hydrofoil on a NACA foil database. Something like this one, though I don’t remember exactly which one I used:
http://m-selig.ae.illinois.edu/ads/coord_database.html
