Good morning all, I’ve hit a wall and have failed to identify what’s causing the issue below. I’ll add context and specs, any help with this will be greatly appreciated.
To sum it up my lines aren’t clean and at the worst case sometimes deformed. The letter H in the picture attached shows it best. The top half is off center. I’m using the following setup:
Xcarve with a Xcontroller
Nema 269oz with 9mm belt upgrade
1/4” 60 vbit with 1/2” D.
Plaque is hickory (a tough choice I had to make, great grain but tough to carve, I reduced the depth pass to .1”) the problem is replicated with cherry.
feed rate 60 in/m
CAD/CAM Aspire. Preview comes out very clean.
I do not have a dial indicator, however the Dewalt 611 has minimal slop. I bought it used and has always been like this. If you press up on the collet and side to side there is very very minimal movement in those directions.
the carriage is very stiff with the stepper motor/belt upgrade. However the mount has very minimal movement if you apply some pressure to the bit while stationary. This is better measured with a dial. But unfortunately unable to do that at this time.
I’m using UGS with the Xcontroller with a Z- Probe to set zero.
Tracks are clean, the belts and gantry are calibrated properly.
Standing by for any additional information that might be needed to trouble shoot.
I apologize for being unable to upload the actual files due to the nature of the plaque.
