Hey there everyone,
First time posting.
Im a beginner here and I have been having quite the trouble getting this DWG file into an SVG that I can work with in Easel. I cant seem to convert the DWG into an SVG and have it still be to scale… When importing into Easel it comes in very small… What am I doing wrong?
Hi there. You likely have a units mismatch. Illustrator is in a larger unit like inch and Easel is in millimeters, so 6 inch object is coming in at 6 mm.
Check that and you should be all set.
