i don’t have a x carve i have a 3018 plus . i was wondering how to combat this . I set up a simple carve the machine has been working fairly well however now for some reason the image size is larger then i had set it up in easel . i tried a few different files and every thing is too large and the positioning is not correct . Any help will be appreciated .
Rich
Did you accidently change the mm/inch setting?
The only reasons a CNC machine dont give correct size is:
- Lost position (stalled motor/noise or whatever) but this will most often only affect one axis, at an artbitrary time/position
- Mismatch between units (mm vs inches as mentioned)
- Mismatch between stated bit diameter vs actual bit diameter
- Incorrect step/mm values for the CNC-controller.
“every thing is too large…”
In what way, slightly larger or way too large?
no inches been using … not sure whats going on . i must have changed something
What are your $100-102 values?
