Image Trace Not Loading
I have attempted numerous times today to upload an image via “Image Trace” and it seems to get stuck at this point in the photo. Nothing happens after this point. Any thoughts, guidance, or tricks?? Thank you in advance.
The Image Trace app is currently working for me. Do you have a link to the image or can you post it?
{:0)
Brandon Parker
So ready
Here it is Brandon. My goal is to invert it and make it a woodblock to print from. I am an artist, btw ;). Thank you for taking an interest!
Jay, that’s an SVG file… you would use the svg import function. Image trace will not render a SVG file :slight_smile:
ahhhhh! OK…I am such a newbie on this machine. So, a jpeg would work here. Brandon, you are a gem! A patient one at that! Thank you.
@JayHandy you also have a lot of garbage around the text. Use the edit mode and you can highlight the garage and delete the nodes.
Thank @SethCNC, he beat me to the punch. When I came back to the thread to see if you had added the image, he had just posted the answer. :slight_smile:
{:0)
Brandon Parker
I’m like a ninja
