I am completely new this CNC arena. I have converted a bitmap file to svg using Pixillion. It imports into Easel and I can open, size, and locate the image. However, when I execute Carve, I get a message saying: " There are no objects in your design that can be carved with your current settings". I am totally lost. Where do I go from here? Any assistance would be greatly appreciated
Please share the project.
However it is very likely that the bit you have selected is simply too large to fit within the width of the design and the design is set to “clear out a pocket” cut type. Either using a smaller bit (such as a vbit) OR changing the cut type to any of the other 3 options MIGHT create a different result and eliminate that fault.
***Always click “simulate” and verify the 3d preview is actually the carve result you desire.
