Share your gcode and/or Fusion file.
Where is your WCS origin set in Fusion?
You’re facing down TO Z-zero.
There will be no cuts below Z-zero. Where did you set zero on the stock?
Do you want it to do something with the wasteboard?
I can’t remember messing with any of that stuff. I only remember setting up the post processor and then importing the saved .nc file into easel. How do I fix?
Zero in Fusion needs to be the same as zero in real life. You have to “mess with that stuff” to run a job.
nevermind. figured it out without doing whatever it was you was talkin about.
Well, there’s no getting around setting your Z-zero, but I’m glad you got it to work.
