Howdy all. I created a file in vcarve, centered on my work piece. When I import the gcode to easel, the file is no longer centered. It looks to be moved about 1/4 inch to the left. I started the carve and then noticed it and then looked at it in easel and noticed it was not centered any more. Any ideas? I’ve created many files on easel and they are all positioned correctly. For some reason when they come from Vcarve they are off.
we’d need to see your vcarve settings. check “x,y datum position” and “offset” within the job settings.
BUT ALSO which post processor are you using when saving the gcode file? is it the “Easel” one??
