Importing SVG file from CorelDRAW
I created a drawing in CorelDraw and exported it as an SVG file. When I try to import the file into Easel, It shows a blank page. Do I need to do something special in CorelDraw so that the SVG file is usable in Easel? The drawing is of a bunch of circles with no fill. Just black outlines. Thanks.
I haven’t used CorelDRAW.
Are you able to run some tests to see if any types of shapes do import correctly?
For example if you draw a line does it import?
Sometimes the program ads a background that hides the vectors.
