Ok so I need to increase my X-carve from 1000mm x 1000mm rails to 1000 mm x 2000mm rails or at least 1800mm range.
I was thinking this should be fairly easily done if I were to just buy the extrusion sized to the dimensions necessary and then purchasing risers and stiffeners from TDB CNC to ensure the rails would be properly trammed.
Is this the proper way to go about increasing the size of the machine?
I need this in order to make cutouts with plywood for a furniture order we had come in from a large client. It will simply save me a lot of time to do this from individual cuts with everything being precise and easier to assemble versus doing this on a table saw and relying on a planer and having to join things manually.
I am already using an upgraded 2.25hp Router that utilizes 1/2" Amana Spektra bits. Needless to say that combined with the TBD CNC Supergrade Z Axis has literally allowed me the ability to just rip through jobs so much faster and much more accurately than oem Axis did.
Ideally I’d be able to upgrade to a screw drive setup here but I’m not going to be picky.
