Hello All. I am new to CNC and require some help. I just bought a used X-Carve (1000mm). Everything seemed to work great. I opened Easel and ran through the Machine setup. It uses the X-Controler and homing switches. I can manually toggle but sometimes it may freeze and I have to restart the application. Once all the config was written I chose to run a test carve. The machine moved on X just a split second and stopped. It was homed to the lower left. The message was: “Error limit switch triggred” or something along those lines.I used UGS, Picsender and Easel. Easle showed
Your Easel screenshot shows that Machine Position is 0,0 (X,Y) when you’re home (front left on an X-carve running Inventables firmware). That position is, for some reason, WORK position 29,29. The WORK zero is the reference for your actual job. In Easel, the origin on the design screen represents work zero.
Your work zero is 29 inches to the left of home… That’s off your machine.
I simply started with the “Carve” button. I don’t remember exactly what happened when i clicked on it but I think it aslked me a couple of querstions which I answered. Maybe incorrectly.
I wonder if you said to “use last home position” instead of setting the zero.
Hard to say about the different machine positions. When you home (machine moves to the switches on its own), the controller should report the same values, regardless of the software you’re using.
Easel uses “Home” for two different things.
When you home the machine, it moves to the limit switches. Easel also calls your Work zero “home” which can be misleading.
