Inkscape help
I am converting a jpg to svg for carving. Unfortunately, the jpg quality is low. I don’t mind cleaning it up but one task is giving me trouble. Three objects are joined together. How do I split them apart?
Thanks!
Screen shot of problem area and svg attached.
Let’s see
Draw a box around around where you want the split
Select the box and the text and then use path “Division” to split
Hope that helps
Worked great! Thanks!
Glad I was able to help
