Trying to make an inlay. I doesn’t matter what image I use, text or regular image, when I import the image in the generator, it doesn’t do an outline and fill carve, it does 2 fill carves of slightly different sizes. What gives???
I’ll answer myself. YOU CAN’T DO PRO FONTS WITH THE INLAY GENERATOR?? Why would you not fix that by now? Why do I pay for Easel Pro if Inventables doesn’t know how to make those Fonts work with the apps?
Honestly, I’m kind of disappointed in Easel and its limitations even with Pro.
It recognizes it as a font, you need to convert it to a path. I cheat and add a dot, combine the dot with the text to create the path then remove the dot. then it will work. Same question comes up when folks are trying to use the script fonts.
If I had to guess he means add a tiny circle to the image, then combine them. Then when you select the new image, you use “edit points” or push “E” and then delete that “dot”.
Since last night I also figured out with Ethan Kinney’s app called Shape Exploder that you can select the text, Explode it, then combine again immediately, and then the inlay generator app works properly.
