Has anyone had any luck connecting this interface: INTERFACE CNC Touch - OpenBuilds Part Store to the X-Controller? I’m looking for a convenient plug and play solution that allows me to jog the machine and send gcode to it that does not require a computer to be plugged in through USB.
I believe you need to be running their hardware/software to communicate.
From the site:
Plug-and-play with OpenBuilds BlackBox Motion Controller
*Note: Can be used with any Grbl 1.1 based controller, which has RX/TX/GND/5V pins (may require you to make your own cabling).
