I have the Arduino IDE version 1.6.11 installed on a Windows 7 machine. When compiling the Inventables fork (as of 8/31/2016) the following error occurs.
On the same machine I then run the Arduino IDE version 1.6.8 from a USB drive with the following results:
[Edit] I have compiled other projects with the 1.6.11 and the 1.6.8 versions without any change in code size.
Looks like you can duplicate the issue by downloading the most current IDE and then build. This for me was 2 bytes short of being over(Verification not upload. Not at my machine).
You can then go into board manager tools -> boards -> board manager. Anything >= 1.6.12 will ballon the size. Where as 1.6.11 is 30,072 bytes. So looks like an issue that needs to be reported to arduino.cc.
I have done a difference check on the 2 and the following changes
avr\ 2 is 1.6.12 and avr is 1.6.11 Files /Users/geoff/Downloads/avr/.DS_Store and /Users/geoff/Downloads/avr 2/.DS_Store differ Files /Users/geoff/Downloads/avr/bootloaders/.DS_Store and /Users/geoff/Downloads/avr 2/bootloaders/.DS_Store differ Files /Users/geoff/Downloads/avr/cores/.DS_Store and /Users/geoff/Downloads/avr 2/cores/.DS_Store differ Files /Users/geoff/Downloads/avr/cores/arduino/Print.cpp and /Users/geoff/Downloads/avr 2/cores/arduino/Print.cpp differ Files /Users/geoff/Downloads/avr/cores/arduino/Stream.h and /Users/geoff/Downloads/avr 2/cores/arduino/Stream.h differ Files /Users/geoff/Downloads/avr/cores/arduino/USBCore.cpp and /Users/geoff/Downloads/avr 2/cores/arduino/USBCore.cpp differ Files /Users/geoff/Downloads/avr/cores/arduino/USBCore.h and /Users/geoff/Downloads/avr 2/cores/arduino/USBCore.h differ Files /Users/geoff/Downloads/avr/cores/arduino/WString.cpp and /Users/geoff/Downloads/avr 2/cores/arduino/WString.cpp differ Files /Users/geoff/Downloads/avr/cores/arduino/WString.h and /Users/geoff/Downloads/avr 2/cores/arduino/WString.h differ Files /Users/geoff/Downloads/avr/libraries/SoftwareSerial/src/SoftwareSerial.h and /Users/geoff/Downloads/avr 2/libraries/SoftwareSerial/src/SoftwareSerial.h differ Files /Users/geoff/Downloads/avr/libraries/Wire/src/utility/twi.c and /Users/geoff/Downloads/avr 2/libraries/Wire/src/utility/twi.c differ Files /Users/geoff/Downloads/avr/platform.txt and /Users/geoff/Downloads/avr 2/platform.txt differ Files /Users/geoff/Downloads/avr/variants/ethernet/pins_arduino.h and /Users/geoff/Downloads/avr 2/variants/ethernet/pins_arduino.h differ Files /Users/geoff/Downloads/avr/variants/gemma/pins_arduino.h and /Users/geoff/Downloads/avr 2/variants/gemma/pins_arduino.h differ Files /Users/geoff/Downloads/avr/variants/leonardo/pins_arduino.h and /Users/geoff/Downloads/avr 2/variants/leonardo/pins_arduino.h differ Files /Users/geoff/Downloads/avr/variants/mega/pins_arduino.h and /Users/geoff/Downloads/avr 2/variants/mega/pins_arduino.h differ Files /Users/geoff/Downloads/avr/variants/robot_control/pins_arduino.h and /Users/geoff/Downloads/avr 2/variants/robot_control/pins_arduino.h differ Files /Users/geoff/Downloads/avr/variants/robot_motor/pins_arduino.h and /Users/geoff/Downloads/avr 2/variants/robot_motor/pins_arduino.h differ Files /Users/geoff/Downloads/avr/variants/standard/pins_arduino.h and /Users/geoff/Downloads/avr 2/variants/standard/pins_arduino.h differ
I need to get some of my own work done right now so if anyone wants to find what has changed enough to take 2,184 bytes go for it.
I know this is a little late, but I compiled the inventables fork of GRBL on the 1.6.12 version (latest version) of the Arduino IDE on windows 10, 64 bit with no size issues.
I actually tested every version of grbl with no size issues.
