Hello can any one tell me how to invert my picture from a negative to a positive. I have cut this many times yet some how it previews visible tool paths in a negative. I would like a positive pic
Can you share the project? I will try to help you out …
{:0)
Brandon Parker
If I understand your intent correctly, try the following:
- Make a rectangle slightly larger than the image itself, set this to whatever depth you want
- The image, set it to zero (0) depth
