Hello, I can’t seem to find the Iot Relay on Amazon anymore, is this discontinued and if so are there any alternatives?
I use a solid state relay from Amazon.
https://www.amazon.com/gp/product/B0087ZTN08/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Thank you!
Currently unavailable too lol
A single click away and this one appears to be in stock…
As is this one, which supposedly has a higher rating…
https://smile.amazon.com/dp/B08RHLCG64/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B08RHLCG64&pd_rd_w=lIXvy&pf_rd_p=887084a2-5c34-4113-a4f8-b7947847c308&pd_rd_wg=2ssrE&pf_rd_r=H7VTH4ETVFT6AZ4FX9CJ&pd_rd_r=8b85e69e-f0e3-4c54-adee-8e0d3ff00afa&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUExN0pLTTU0U0pOMUdQJmVuY3J5cHRlZElkPUEwNzAyOTI1MVA0TEVWTzZETkc3JmVuY3J5cHRlZEFkSWQ9QTAzNDIwMTcxUDVMVUxXUkpSTkVBJndpZGdldE5hbWU9c3BfZGV0YWlsJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
{:0)
Brandon Parker
You wouldn’t need solid state either. Just a regular old electromagnetic relay would work fine.
Thank you, is it easy to set up?
You should be comfortable with electronics and typical home voltages. You would need to acquire a relay (solid-state or mechanical) or a good little contactor, an enclosure, appropriate wiring, and an outlet or two. It’s not something that I would consider difficult at all, but some people are not comfortable with that kind of stuff.
If you are looking for an easy and out-of-the-box solution then building it wouldn’t be for you.
After some digging, I actually found a site that says they have Qty:(1). They are out of Canada…
{:0)
Brandon Parker
Before giving up try chatting with Digital Loggers on their web site. I just got one ordered from them even though they say they’re out of stock.
