Hi guys,
I’m having a problem with my x-carve on my last cuts.
As you can see on the pictures, the cuts are not regular at some points
Does anyone have an idea about where this could come from?
Thanks in advance for your help.
Hi guys,
I’d check belt tension. Belt quality (no missing teeth of stretched parts)
And make sure eccentric nuts on the vwheels are properly adjudged… both of these are discussed here:
Thanks, I will check that then.
