We have an x carve router machine and are looking to expand with a laser and rotary attachment. Do you have any suggestions on how to go about our expansion ideas?
You can add just about any diode laser module, but the most common, best documented one is the jtech.
Regarding the rotary, well, there really isn’t any thoroughly documented plug n play solution, but there are other threads that discuss methods for adding rotaries. It’s not the most straight forward process and requires altering key settings that would need to be put back anytime you want to use the spindle to carve…
