when using my thunder laser and Lightburn you can frame an object so that you know where it is going to burn it. is there something like that in Easel? if so I cant find it and would love a point in the right direction. thanks!
You could place a box or outline around the carve with a very shallow cut, then go through the Carve Process and set your “Z” above the surface and let it “Air Carve”.
This would be the closest I think you will get to “Framing” on the cnc.
