Is there any way to safely move the gantry manually
Is there any way to safely move the gantry manually? Or is there a way to easily/quickly make the jog’s longer temporally?
You can put in any lenght of move you want below the xy and z movements in the custom box.
Thanks Wayne. I will give that a try in the morning. Fast answer!!! Wow!
How do you make the change? I’m putting a number in the custom box, How do I assign it to the command box?
The custom entry only applies to x,y but you just type it in then click the arrow for x or y
Thank you
