Looking for help with importing a STL I bought on Etsy. I used the import STL option in EASEL PRO but it only loads in showing toolpaths. No options to carve or do anything else. I tried another STL ant that one loaded fine. Any suggestions? Is there a Hotkey to take it to another mode?
You might need to contact the seller of the file because it might be corrupt. If you know how to fix stl files you can download mesh lab and fix it your self .
This doesn’t sound right.
Can you share this easel project? Go To Project>Share, then set it to “unlisted” then copy the link shown, make sure to hit save before exiting… Then paste that link over here (or in a DM if you prefer)
