I have been trying to make some jigsaw puzzle using some simple pictures i’ve found online. When I try and import, create an svg in both Adobe IA and Inkscape I always get 2 set of line on the outside and inside, when these are imported into Easel it reads them as 2 cut lines which makes the cuts even bigger. I have even spent time using the pen tool in Adobe IA to do a manual trace and get the same problem.
I’m sure I’m not the only one who has come across this problem and I’m sure them is a SVG God in the Forum who maybe able to help
it’s a worthless file to start with.
you’re getting two lines because it sees the lines as shapes (very thin ones, but shapes nontheless)
I guess it’s the result of an automated trace judgung from the lines’ inconsistency.
Let me see if I can work with it. give me a minute
Would image trace work for your purposes? Seems as though you could just import the jpeg file directly in to Easel and work with that.
![test](//discuss-assets.s3.amazonaws.com/original/3X/a/e/ae8be2ff25baa5db39c1568a9e9592836b4e955b.svg)
this one should be better… not perfect but considering the poor original…
I manually used the pen tool and made my own trace over the lines and I get the same effect. Ill see if I can post it upcz-bear.ai (59.4 KB)
now you have to tell me how you did that Sir?
in this particular instance i just deleted the outside perimeter which left the 3 separate pieces outline. There was some manual cleanup though because some of the lines were interrupted which was invisible because of the added stroke. So yeah a lot was wrong with it ![:wink: :wink:](https://discuss.inventables.com/images/emoji/apple/wink.png?v=9)
I suggest to do the following for other pieces:
get comfortable with your software and know the difference between strokes, fills, lines and shapes.
start off with separate pieces like I arranged them. Autotrace with lines as output. Illustrator has the option in the autotrace panel
