Hello every body,
My name is Zhengwei and I’m a wood worker in China.
Very recently, I built myself an Arduino uno 3 based cnc machine. I’m using Fusion 360 for CAM and Estlcam as the G-code sender to my machine. In the past three days, I have tried to post processing all the file types that Estlcam can accept, and the results were not pleasant. In the tool path preview window, the paths were not looking correct with broken lines and shapes. I ran the machine and indeed it made a mass and almost broke my tool. Only one or two Post processor I tried with a .nc file were usable but no code generated on drilling operation.
The EstlCam version is 11.009, I’m still on testing, I haven’t purchased the software. I tried to export with GRBL processor in Fusion 360 and have the file open in the Universal G-code Sender, the tool path looked right. I don’t want to give up on EstlCam.
Below is the tool path simulator in Fusion 360
Below is the tool path preview in Estlcam, post processor used in fusion is GRBL , the tool path is broken and looks like no drilling tool path.
I have tried mach3mill, linuxcnc and a lot more, the results are mostly the same or worse, well, it’s same since I can’t run the program.
I’m really new to cnc, Could anyone help me please?
Best Regards
Zhengwei
