Thought I would try my hand at doing Inlays. Female part carved great in oak. The male part not so good ! The clearance part ran pretty good .125 down cut end mill the. I switched to a 60 degree vbit doc was .20. The v carve started and cut some of the letters out
I’ve had great luck with the inlay tool, but only when using 1/16 or 1/32 bits. When I use 1/8, they don’t seem to work as well, unless it is a super-simple inlay.
Thank you for your input. I’m going to get some smaller bits. I’ve just recently looked at carving . I originally bought the xcarve to cut out frames for quad copters. I’ve v carved a few things I mostly have 1/4" and 1/8" end mills. A few v bits and a couple of flattening bit. I guess if I’m going to up my game I’m going to have to up my bits as well lol. I appreciate your response!
The Inlay generator is setup for endmills only, the size of endmill that you enter into the tool… There are ways to use V Bits to make inlays after using the inlay generator, but added steps are necessary for it to come out properly… Alo for best results a steep angle V bit (like a 20 degree) and endgrain of the wood tends to provide best results… the endrain provides best strength for smaller pieces to prevent then from snapping off.
Check out Bro In Wood on youtube, he doesn’t cover the designing process because he uses a software that does it all properly for a VBit without the manual manipulation needed in Easel. However, watching his process and the carved results step by step, will help to learn what you would be looking for in the simulation pane, https://www.youtube.com/c/Broinwood
